Capacitor Tester
Thanks Codefox1. What you said is also my understanding of circuits, but I add limited understanding. Sitting around the campfire a friend, hearing I was undertaking a restoration project, said I should get one. Maybe for curosity sake.
Capacitor Tester - by wakani - 10-09-2011, 10:49 PM
Re: Capacitor Tester - by codefox1 - 10-10-2011, 07:44 AM
Re: Capacitor Tester - by wakani - 10-10-2011, 09:19 AM
Re: Capacitor Tester - by sables2 - 12-11-2011, 02:22 PM
Re: Capacitor Tester - by BDM - 12-11-2011, 04:21 PM
Re: Capacitor Tester - by TA Forbes - 12-11-2011, 11:16 PM
91H Code 126 Restore
