Grill cloth problems
I'm having problems with my new grill cloth sagging. I'm using an upholstery fabric with fiber backing, glued to a heavy weight cardboard using fabric glue. The cloth is sagging at each of the openings. I'm thinking that the glue is shrinking & stretching the fabric. Any suggestions on how to prevent this?
Grill cloth problems - by Dave - 10-10-2011, 09:30 PM
Re: Grill cloth problems - by TA Forbes - 10-10-2011, 09:43 PM
Re: Grill cloth problems - by codefox1 - 10-11-2011, 01:42 AM
Re: Grill cloth problems - by exray - 10-11-2011, 06:00 AM
Re: Grill cloth problems - by Dave - 10-11-2011, 08:35 AM
