My latest cabinet refinishing projects
All I could possibly add to the fine work that I have seen here is that a piece of wood solid oe laminated has four dimensions, and it is best if totally dry and sealed. Of course it matters not what the inside looks like, but give it a break, at least a cote or two of shellac.
Re: My latest cabinet refinishing projects - by codefox1 - 10-11-2011, 01:33 AM
There are currently 10546 online users. [Complete List]
» 3 Member(s) | 10543 Guest(s)
