AC/DC radio pilot light bulbs
Hi Tom
Since the heater string is 150ma I'd go with a #47. The 44 is a 250ma job. I didn't look at the diagram to see if there are resistors in the circuit to limit the current. Also check the paper caps around the 35Z5 those will take out the lamp and the tap on the heater too.
AC/DC radio pilot light bulbs - by TA Forbes - 10-10-2011, 09:57 PM
Re: AC/DC radio pilot light bulbs - by John R - 10-10-2011, 10:44 PM
Re: AC/DC radio pilot light bulbs - by 7estatdef - 10-11-2011, 07:40 AM
Re: AC/DC radio pilot light bulbs - by TA Forbes - 10-11-2011, 02:00 PM
Re: AC/DC radio pilot light bulbs - by 7estatdef - 10-11-2011, 02:56 PM
Re: AC/DC radio pilot light bulbs - by Arran - 10-12-2011, 01:17 AM
Re: AC/DC radio pilot light bulbs - by LASJayhawk - 10-29-2011, 11:13 PM
91H Code 126 Restore
Philco 70 antenna lead
