cap question
Not having access to my service info at the moment, I'd guess those 1000 volt caps connect from the plate of each output tube to ground? There has been a lot of discussion on this subject in recent years. It is generally agreed that 1000 volt caps should be used as protection against transients/spikes in the audio circuit - although I confess I have used 630 volt caps in this application and have had no problems. However, I should also point out that I don't run my sets at full volume, nor do I generally run old sets for hours on end. YMMV.
cap question - by OzRadio - 09-03-2006, 07:15 PM
Re: cap question - by n9vu - 09-04-2006, 08:06 AM
[No subject] - by Ron Ramirez - 09-19-2006, 09:04 AM
