Philco 80 oscillator
My philco 80 oscillator measured 17ohms on one coil and 24 on the other side. Small coil measured 4ohms. These are not in spec with the schematic, will it be ok?
Philco 80 oscillator - by johnfin - 10-12-2011, 01:02 PM
Re: Philco 80 oscillator - by johnfin - 10-12-2011, 04:27 PM
Re: Philco 80 oscillator - by 7estatdef - 10-12-2011, 05:51 PM
Re: Philco 80 oscillator - by johnfin - 10-12-2011, 07:53 PM
Re: Philco 80 oscillator - by 7estatdef - 10-12-2011, 08:44 PM
Re: Philco 80 oscillator - by johnfin - 10-13-2011, 08:22 AM
Re: Philco 80 oscillator - by johnfin - 10-13-2011, 08:23 AM
Re: Philco 80 oscillator - by 7estatdef - 10-13-2011, 05:51 PM
Philco the squirrel - by johnfin - 10-17-2011, 10:02 PM
Re: Philco 80 oscillator - by 7estatdef - 10-18-2011, 05:26 PM
The speaker table error?
Philco 70 antenna lead
