Philco 80 oscillator
Seems like it's OK, usually what goes bad is the cathode winding. Have you tried it to see if the osc is running? If you've got it out do you see any green on the windings? Just had one on a model 84 that looked good but was open.
Got an 80 myself wait to be serviced.
Philco 80 oscillator - by johnfin - 10-12-2011, 01:02 PM
Re: Philco 80 oscillator - by johnfin - 10-12-2011, 04:27 PM
Re: Philco 80 oscillator - by 7estatdef - 10-12-2011, 05:51 PM
Re: Philco 80 oscillator - by johnfin - 10-12-2011, 07:53 PM
Re: Philco 80 oscillator - by 7estatdef - 10-12-2011, 08:44 PM
Re: Philco 80 oscillator - by johnfin - 10-13-2011, 08:22 AM
Re: Philco 80 oscillator - by johnfin - 10-13-2011, 08:23 AM
Re: Philco 80 oscillator - by 7estatdef - 10-13-2011, 05:51 PM
Philco the squirrel - by johnfin - 10-17-2011, 10:02 PM
Re: Philco 80 oscillator - by 7estatdef - 10-18-2011, 05:26 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 5734 online users. [Complete List]
» 1 Member(s) | 5733 Guest(s)
