Mershon Caps
Could you post the measurements on those things before you take them apart?
Mershon Caps - by ipwizard - 10-12-2011, 10:34 PM
Re: Mershon Caps - by Phlogiston - 10-12-2011, 10:57 PM
Re: Mershon Caps - by TA Forbes - 10-12-2011, 11:04 PM
Re: Mershon Caps - by ipwizard - 10-12-2011, 11:41 PM
Re: Mershon Caps - by Phlogiston - 10-13-2011, 12:10 AM
Re: Mershon Caps - by Arran - 10-13-2011, 12:54 AM
91H Code 126 Restore
Philco 70 antenna lead
