Mershon Caps
Phlogiston Wrote:Could you post the measurements on those things before you take them apart?
Sure thing.
From the top of the cap to where the copper housng ends is 4 5/16", the over all length to the end of the stud at the bottom is 5 1/8", and the diameter is 1 3/8".
[Image: http://i1129.photobucket.com/albums/m501...AG0720.jpg]
Hope that helps you out.
TA, ill give your idea a shot tomorrow. I have one of then im the freezer for the night, might try to run my little tourch around the cap while the body is cold maybe the cap will swell enough to come loose.
-Keith
Mershon Caps - by ipwizard - 10-12-2011, 10:34 PM
Re: Mershon Caps - by Phlogiston - 10-12-2011, 10:57 PM
Re: Mershon Caps - by TA Forbes - 10-12-2011, 11:04 PM
Re: Mershon Caps - by ipwizard - 10-12-2011, 11:41 PM
Re: Mershon Caps - by Phlogiston - 10-13-2011, 12:10 AM
Re: Mershon Caps - by Arran - 10-13-2011, 12:54 AM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 7030 online users. [Complete List]
» 2 Member(s) | 7028 Guest(s)
