Philco 80 oscillator
I think it would be better to test it in circuit. The coil has a few windings on in and it might be easier to figure out by seeing if it will oscillate rather than the resonance of the windings. Does your set use #36 tubes? I've got a couple of model 84's those have round cans but use #77 tubes
Philco 80 oscillator - by johnfin - 10-12-2011, 01:02 PM
Re: Philco 80 oscillator - by johnfin - 10-12-2011, 04:27 PM
Re: Philco 80 oscillator - by 7estatdef - 10-12-2011, 05:51 PM
Re: Philco 80 oscillator - by johnfin - 10-12-2011, 07:53 PM
Re: Philco 80 oscillator - by 7estatdef - 10-12-2011, 08:44 PM
Re: Philco 80 oscillator - by johnfin - 10-13-2011, 08:22 AM
Re: Philco 80 oscillator - by johnfin - 10-13-2011, 08:23 AM
Re: Philco 80 oscillator - by 7estatdef - 10-13-2011, 05:51 PM
Philco the squirrel - by johnfin - 10-17-2011, 10:02 PM
Re: Philco 80 oscillator - by 7estatdef - 10-18-2011, 05:26 PM
91H Code 126 Restore
Philco 70 antenna lead
