Philco And The LP
It makes as much sense as having VHS and Beta, or blu-ray and HDDVD...
but once the standard is out, changing it would make even les sense. While we might not agree about having the standard to begin with, changing it wouldn't make more sense.
Technically, if the record spins faster, don't you have a better "resolution" to store data, so "better sound quality"? Or am I thinking too digitally here.?
-Mars
Philco And The LP - by PHILLYPHILCO - 10-11-2011, 08:00 PM
Re: Philco And The LP - by PHILLYPHILCO - 10-11-2011, 08:20 PM
Re: Philco And The LP - by Ron Ramirez - 10-11-2011, 08:26 PM
Re: Philco And The LP - by Chuck Schwark - 10-11-2011, 09:44 PM
Re: Philco And The LP - by Doug Houston - 10-12-2011, 10:32 PM
Re: Philco And The LP - by Arran - 10-13-2011, 01:19 AM
Re: Philco And The LP - by Don Lind - 10-13-2011, 01:59 PM
Re: Philco And The LP - by Arran - 10-13-2011, 07:40 PM
Re: Philco And The LP - by Marsupial - 10-13-2011, 10:40 PM
Re: Philco And The LP - by Arran - 10-14-2011, 01:18 AM
Re: Philco And The LP - by Marsupial - 10-14-2011, 09:24 AM
Re: Philco And The LP - by Arran - 10-15-2011, 12:20 AM
Re: Philco And The LP - by Doug Houston - 10-20-2011, 12:02 AM
Re: Philco And The LP - by Arran - 10-20-2011, 10:41 PM
Re: Philco And The LP - by Jayce - 10-21-2011, 02:56 PM
There are currently 10612 online users. [Complete List]
» 2 Member(s) | 10610 Guest(s)
