Introduction and 42-380 questions
Ah, I DO have the electrical specs for your transformer...here they are:
Primary 120 volts, 60 cycles
Secondary 1: 525VCT, 75 mA
Secondary 2: 6.4V, 4.3A
Dimensions 2-1/2" L x 3" W x 3-3/8" H, 2-1/4" mounting centers.
Your replacement should have the same specs as the original, although slightly higher high voltage is acceptable as is higher current capability. Lower specs than original is NOT acceptable. It should be the same physical size as the original to avoid problems.
Introduction and 42-380 questions - by Steve D - 07-27-2006, 08:50 AM
[No subject] - by Ron Ramirez - 09-19-2006, 09:05 AM
[No subject] - by Ron Ramirez - 09-19-2006, 09:42 AM
Eico 232 VTVM Schematic
There are currently 3210 online users. [Complete List]
» 2 Member(s) | 3208 Guest(s)
