What Audio Transformer To Buy?
I'd just like to clarify the connections on this Hammond 125B audio transformer I just put into this 40-190. Primary side's pretty simple but I want to make sure that I have my secondary side correct. My voice coil reads about 4 ohms so I'm using pins 4 & 5 of the transformers secondary. Pin 4 is connected to chassis ground and pin 5 to my speaker. Is this correct?
http://www.nostalgiaair.org/PagesByModel...013339.pdf
http://www.hammondmfg.com/pdf/5c0054.pdf
Pepper
"It's Nice To Be Nice To The Nice"
Major Frank Burns Mash 4077th
What Audio Transformer To Buy? - by Pepperoni - 09-27-2011, 05:00 PM
Re: What Audio Transformer To Buy? - by codefox1 - 09-27-2011, 05:16 PM
Re: What Audio Transformer To Buy? - by Pepperoni - 09-27-2011, 07:45 PM
Re: What Audio Transformer To Buy? - by John R - 09-27-2011, 11:27 PM
Re: What Audio Transformer To Buy? - by Pepperoni - 10-14-2011, 10:45 AM
Re: What Audio Transformer To Buy? - by John R - 10-14-2011, 11:50 AM
Re: What Audio Transformer To Buy? - by Pepperoni - 10-14-2011, 01:52 PM
Re: What Audio Transformer To Buy? - by exray - 10-15-2011, 08:30 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3479 online users. [Complete List]
» 2 Member(s) | 3477 Guest(s)
