40-190 RF Problems - Need Help
The oscillator is working as stated above. An alignment is showing me nothing and I've checked all my connections and they are correct. My big question now is the 1.4 ohms that I see between the pushbutton bus and ground. This 1.4 ohms doesn't show on my -185 (same chassis) and the same schematic applies to my-190. My -185 even has the run 4 6J8 in place of the 7J7. Should I have this 1.4 ohms on the PB bus?
Pepper
"It's Nice To Be Nice To The Nice"
Major Frank Burns Mash 4077th
40-190 RF Problems - Need Help - by Pepperoni - 10-15-2011, 03:47 PM
Re: 40-190 RF Problems - Need Help - by Pepperoni - 10-15-2011, 08:00 PM
Re: 40-190 RF Problems - Need Help - by Arran - 10-16-2011, 10:11 PM
Re: 40-190 RF Problems - Need Help - by Pepperoni - 10-16-2011, 11:09 PM
Re: 40-190 RF Problems - Need Help - by Arran - 10-16-2011, 11:19 PM
Re: 40-190 RF Problems - Need Help - by Pepperoni - 10-17-2011, 12:30 PM
Re: 40-190 RF Problems - Need Help - by codefox1 - 10-17-2011, 04:19 PM
Re: 40-190 RF Problems - Need Help - by 7estatdef - 10-17-2011, 05:08 PM
Re: 40-190 RF Problems - Need Help - by Pepperoni - 10-17-2011, 05:32 PM
Re: 40-190 RF Problems - Need Help - by Pepperoni - 10-18-2011, 01:49 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 5706 online users. [Complete List]
» 1 Member(s) | 5705 Guest(s)
