volume control
Terry is correct, it is 20K. Part no. 7439 was used in model 80 and the three-knob 81.
volume control - by johnfin - 10-15-2011, 10:24 PM
Re: volume control - by 7estatdef - 10-15-2011, 10:41 PM
Re: volume control - by ipwizard - 10-15-2011, 10:42 PM
Re: volume control - by Ron Ramirez - 10-16-2011, 07:30 AM
Re: volume control - by 7estatdef - 10-16-2011, 08:06 AM
Re: volume control - by Ron Ramirez - 10-16-2011, 09:17 AM
Re: volume control - by johnfin - 10-16-2011, 10:11 AM
Re: volume control - by codefox1 - 10-16-2011, 11:24 AM
Re: volume control - by 7estatdef - 10-16-2011, 06:02 PM
91H Code 126 Restore
Philco 70 antenna lead
