volume control
I unsoldered one outer lug, not the one to ground and measured it like a resistor, 17 ohms.
Strange, then I unsoldered the center lug and it read 27k. I thought you can measure a pot like a resistor if one of the outer lugs is disconnected.
volume control - by johnfin - 10-15-2011, 10:24 PM
Re: volume control - by 7estatdef - 10-15-2011, 10:41 PM
Re: volume control - by ipwizard - 10-15-2011, 10:42 PM
Re: volume control - by Ron Ramirez - 10-16-2011, 07:30 AM
Re: volume control - by 7estatdef - 10-16-2011, 08:06 AM
Re: volume control - by Ron Ramirez - 10-16-2011, 09:17 AM
Re: volume control - by johnfin - 10-16-2011, 10:11 AM
Re: volume control - by codefox1 - 10-16-2011, 11:24 AM
Re: volume control - by 7estatdef - 10-16-2011, 06:02 PM
91H Code 126 Restore
Philco 70 antenna lead
