volume control
Depending on the circuit this may not be true, IE this case. However if the wiper is all the way toward the still connected end you should be able to get an accurate reading. Then you could connect the ohmmeter between the center and unconnected end and sweep it, and you will then see if there are any open spots.
volume control - by johnfin - 10-15-2011, 10:24 PM
Re: volume control - by 7estatdef - 10-15-2011, 10:41 PM
Re: volume control - by ipwizard - 10-15-2011, 10:42 PM
Re: volume control - by Ron Ramirez - 10-16-2011, 07:30 AM
Re: volume control - by 7estatdef - 10-16-2011, 08:06 AM
Re: volume control - by Ron Ramirez - 10-16-2011, 09:17 AM
Re: volume control - by johnfin - 10-16-2011, 10:11 AM
Re: volume control - by codefox1 - 10-16-2011, 11:24 AM
Re: volume control - by 7estatdef - 10-16-2011, 06:02 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3477 online users. [Complete List]
» 2 Member(s) | 3475 Guest(s)
