Another Condenser Question Model 46-1213
Electrolytic condenser can C54 both A and B sections are 10 MF according to the schematic (Rider). The actual values as listed on the can shows 10MF for A and 15MF for B. No question in my mind but to go with 10 and 15.
Right decision?
Another Condenser Question Model 46-1213 - by wakani - 10-16-2011, 05:17 PM
The speaker table error?
Philco 70 antenna lead
There are currently 5884 online users. [Complete List]
» 1 Member(s) | 5883 Guest(s)
