Truetone D2210
Several of the Silvertone "green dial" sets from 1935/36 used an inductive volume control and on the 1905/55/65 sets an inductive tone control.
Truetone D2210 - by Jayce - 10-14-2011, 07:34 PM
Re: Truetone D2210 - by TA Forbes - 10-14-2011, 10:36 PM
Re: Truetone D2210 - by Jayce - 10-14-2011, 10:47 PM
Re: Truetone D2210 - by Texasrocker - 10-15-2011, 08:51 PM
Re: Truetone D2210 - by Jayce - 10-15-2011, 10:43 PM
Re: Truetone D2210 - by exray - 10-16-2011, 05:36 AM
Re: Truetone D2210 - by Arran - 10-16-2011, 11:38 PM
Re: Truetone D2210 - by Texasrocker - 10-16-2011, 11:47 PM
Re: Truetone D2210 - by Texasrocker - 10-17-2011, 12:03 AM
Re: Truetone D2210 - by TA Forbes - 10-17-2011, 08:44 AM
Re: Truetone D2210 - by Jayce - 10-17-2011, 02:09 PM
Re: Truetone D2210 - by TA Forbes - 10-17-2011, 11:38 PM
Re: Truetone D2210 - by Jayce - 10-18-2011, 11:59 AM
Re: Truetone D2210 - by Texasrocker - 10-29-2011, 08:16 PM
Re: Truetone D2210 - by Jayce - 10-29-2011, 11:14 PM
Re: Truetone D2210 - by Texasrocker - 10-30-2011, 03:39 PM
Re: Truetone D2210 - by Jayce - 10-30-2011, 05:24 PM
Re: Truetone D2210 - by philconerd - 11-30-2011, 10:20 PM
Philco 91 Tuning Condenser
