Speaker Cone Restoration - 46-1213
This morn' I pulled the speaker. It is has no tears, the surrounds are good. The cone is bone dry and very brittle, WoW, after only 64 years of service.
I plan to use Ailene's Tacky Glue, mixing 1:1 water/glue, carefully and lightly paint the entire surface of the cone. After that dries, with a 1:2 water/glue mixture, I will again paint the entire surface. I do not think that this will afect the sonics, much if at all, but should give that old speaker a couple more years of life? Thinking the 1:1 mixture would be ok, but might mix 2:1 water/glue for the first go.
Any thoughts?
Speaker Cone Restoration - 46-1213 - by wakani - 10-17-2011, 10:23 AM
Re: Speaker Cone Restoration - 46-1213 - by Arran - 10-18-2011, 09:19 PM
Re: Speaker Cone Restoration - 46-1213 - by Arran - 10-19-2011, 07:31 PM
The speaker table error?
Philco 70 antenna lead
There are currently 5618 online users. [Complete List]
» 1 Member(s) | 5617 Guest(s)
