Need Philco 345 readable schematic
Thank you Ron.. I do have the same RCC disk and it is not very readable,that is why I put the request on the forum.
I will see if I can decipher the schematic.
   Living in Calgary Alberta
Re: Need Philco 345 readable schematic - by Dan Walker - 11-18-2011, 12:05 PM
The speaker table error?
Philco 70 antenna lead
There are currently 7109 online users. [Complete List]
» 2 Member(s) | 7107 Guest(s)
