42-355 Osc problem on BC/SW, PB work OK
Double check the switch that switches from the pushbuttons to the dial.
Re: 42-355 Osc problem on BC/SW, PB work OK - by 7estatdef - 10-17-2011, 05:16 PM
91H Code 126 Restore
Philco 70 antenna lead
