16B question
If it's complete and the cabinet in good to excellent condition, I would say between $150 to under $300, fair condition maybe between $100 to $200. Parts missing and a rough cabinet would obviously make it worth less. Fleabay is all over the map, I saw one in semi complete but rough condition go for over $400 (way too much) but saw another in much nicer condition go for under $275. I remember this because a guy on the other forum was trying to argue that the $400 beater wouldn't need over $200 worth of work and materials which was laughable, that was quite an assumption to make on a set with a rusty chassis. I work by the ALASP principle, even though these are an excellent series of sets they are not rare, not extremely common like a model 620 but they do come up on a regular basis, if you can't get one for the condition and price you want just wait a while.
16B question - by thirtiesradio - 09-22-2011, 06:15 PM
Re: 16B question - by Ron Ramirez - 09-22-2011, 07:53 PM
Re: 16B question - by Marsupial - 09-22-2011, 09:26 PM
Re: 16B question - by thirtiesradio - 09-22-2011, 10:09 PM
Re: 16B question - by TA Forbes - 09-23-2011, 09:55 PM
Re: 16B question - by thirtiesradio - 09-24-2011, 05:02 PM
Re: 16B question - by Allen in SB - 09-30-2011, 09:14 PM
Re: 16B question - by thirtiesradio - 09-30-2011, 11:05 PM
Re: 16B question - by Arran - 10-18-2011, 01:39 AM
Re: 16B question - by thirtiesradio - 10-21-2011, 11:06 PM
There are currently 9924 online users. [Complete List]
» 3 Member(s) | 9921 Guest(s)
