40-190 RF Problems - Need Help
New .05 cap between 7B7 pin 3 and ground bad. Replaced it, set works fine.
Pepper
"It's Nice To Be Nice To The Nice"
Major Frank Burns Mash 4077th
40-190 RF Problems - Need Help - by Pepperoni - 10-15-2011, 03:47 PM
Re: 40-190 RF Problems - Need Help - by Pepperoni - 10-15-2011, 08:00 PM
Re: 40-190 RF Problems - Need Help - by Arran - 10-16-2011, 10:11 PM
Re: 40-190 RF Problems - Need Help - by Pepperoni - 10-16-2011, 11:09 PM
Re: 40-190 RF Problems - Need Help - by Arran - 10-16-2011, 11:19 PM
Re: 40-190 RF Problems - Need Help - by Pepperoni - 10-17-2011, 12:30 PM
Re: 40-190 RF Problems - Need Help - by codefox1 - 10-17-2011, 04:19 PM
Re: 40-190 RF Problems - Need Help - by 7estatdef - 10-17-2011, 05:08 PM
Re: 40-190 RF Problems - Need Help - by Pepperoni - 10-17-2011, 05:32 PM
Re: 40-190 RF Problems - Need Help - by Pepperoni - 10-18-2011, 01:49 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6065 online users. [Complete List]
» 1 Member(s) | 6064 Guest(s)
