Cap replacement on 37-630X console
kbm37-630 Wrote:For example if you need a 50K ohm 1/2 watt can you use a 47.5K to 52.5K 1/2 watt resistor, within +/- 5% ?
47k is the normal replacement value for an older 50k.
Quote:I believe I read that caps can vary by 20% of specified value, is this correct? ? If so, does in hold true for all caps electrolytic or non-electrolytic ?
More or less. Old electrolytics sometimes had a wide range, as much as -50 to +100%. That doesn't imply that you should use a replacement that far off but the standard values, just like the resistors, are different these days. Use the closest available value.
Quote:What do you do in a case such as " .015 - .015 mfd - double bakelite ?
.015 can be found. This may be a loaded question in this example if that is the AC line bypass cap. They were often a dual .015. There's a special type of cap that is preferred in AC-line bypassing nowadays.
No need to get nutty trying to achieve the exact values of the old components. If you're within 20% you'll almost always be within spec.
-Bill
Cap replacement on 37-630X console - by kbm37-630 - 10-17-2011, 07:01 PM
Re: Cap replacement on 37-630X console - by Arran - 10-17-2011, 11:08 PM
Re: Cap replacement on 37-630X console - by exray - 10-18-2011, 04:31 PM
Re: Cap replacement on 37-630X console - by exray - 10-18-2011, 06:14 PM
Re: Cap replacement on 37-630X console - by exray - 10-21-2011, 03:51 PM
91H Code 126 Restore
Philco 70 antenna lead
