Cap replacement on 37-630X console
Not the caps. Probably the grease in the switch has petrified. Try shooting some WD40 inside the assembly.
So many questions but keep asking away.
Richard
Cap replacement on 37-630X console - by kbm37-630 - 10-17-2011, 07:01 PM
Re: Cap replacement on 37-630X console - by Arran - 10-17-2011, 11:08 PM
Re: Cap replacement on 37-630X console - by exray - 10-18-2011, 04:31 PM
Re: Cap replacement on 37-630X console - by rghines1 - 10-18-2011, 05:48 PM
Re: Cap replacement on 37-630X console - by exray - 10-18-2011, 06:14 PM
Re: Cap replacement on 37-630X console - by exray - 10-21-2011, 03:51 PM
91H Code 126 Restore
Philco 70 antenna lead
