Restoring a Model 89-123 I think
On the link I gave you to the 89 page on my site, if you click on any small schematic it brings up a larger schematic. Click it again and it enlarges again, clearly showing the part values.
If you want the complete data including parts list, etc., you need to contact Chuck Schwark at the Philco Repair Bench. The $7.00 fee is well worth it for the quality of info you get. Use his info along with what I have given on my 89 page for complete coverage.
http://www.philcorepairbench.com/schematics.htm
Restoring a Model 89-123 I think - by brodie - 10-19-2011, 05:24 PM
Re: Restoring a Model 89-123 I think - by brodie - 10-19-2011, 06:22 PM
Re: Restoring a Model 89-123 I think - by Ron Ramirez - 10-19-2011, 07:20 PM
Re: Restoring a Model 89-123 I think - by brodie - 10-19-2011, 08:55 PM
91H Code 126 Restore
Philco 70 antenna lead
