118H, Original Wood Color/Finish-Updated with Photo
I have a Model 118H specifically in mind but this is a general cabinet question.
With a deteriorated finish from age that is checked, peeling, darkened, etc. how can a person tell what was the original Philco wood finish. Walnut? Oak????
Also I have a problem with a 118H legs, looks to be laminated wood that was stained. Could the base wood have been poplar? If not what other wood?
Mike
Note from site admin: Sorry, but the photo which was attached to this post is no longer available.
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
There are currently 10420 online users. [Complete List]
» 2 Member(s) | 10418 Guest(s)
