Model 76 output transformer
I have a Philco #76 on the bench, the output transformer primary is open. The radio uses two 45's in push-pull and the VC winding resistance is very low - less than one ohm from memory. The part number is 2848T.
Should I just go with a universal replacement transformer?
Wondering if anyone knows the proper impedance values for a replacement?
Thanks!
-Sam T.
Model 76 output transformer - by SamTanner - 10-20-2011, 12:21 PM
Re: Model 76 output transformer - by John R - 10-20-2011, 02:43 PM
Re: Model 76 output transformer - by Ron Ramirez - 10-20-2011, 06:34 PM
Re: Model 76 output transformer - by SamTanner - 10-20-2011, 07:38 PM
Re: Model 76 output transformer - by John R - 10-20-2011, 08:02 PM
Re: Model 76 output transformer - by SamTanner - 10-20-2011, 08:23 PM
Re: Model 76 output transformer - by Arran - 10-20-2011, 10:03 PM
The speaker table error?
Philco 70 antenna lead
There are currently 5775 online users. [Complete List]
» 1 Member(s) | 5774 Guest(s)
