tone control
Ok Ron, Ill heed your warning and come up with a .02 cap for the tone control.
Off Topic a bit:
I read somewhere where you changed the tone curcuit of your 71 making it sound much better. Do you have instructions for this? Is it an easy thing to do without having to rewire a bunch of stuff?
-Keith
tone control - by ipwizard - 10-19-2011, 11:43 PM
Re: tone control - by codefox1 - 10-20-2011, 07:48 AM
Re: tone control - by Ron Ramirez - 10-20-2011, 08:24 AM
Re: tone control - by ipwizard - 10-20-2011, 02:55 PM
Re: tone control - by Ron Ramirez - 10-20-2011, 05:00 PM
Re: tone control - by ipwizard - 10-20-2011, 05:06 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3413 online users. [Complete List]
» 1 Member(s) | 3412 Guest(s)
