Antenna choice
gvel Wrote:Gotta wonder what the special Philco antenna was. Does anyone know?
I think it was just an antenna "kit", one with a lead in wire, an antenna wire, a pair of insulators, and possibly a lightning arrestor.
Antenna choice - by kbm37-630 - 10-18-2011, 05:52 PM
Re: Antenna choice - by exray - 10-18-2011, 06:23 PM
Re: Antenna choice - by gvel - 10-20-2011, 06:27 PM
Re: Antenna choice - by Arran - 10-20-2011, 11:11 PM
Re: Antenna choice - by Tom Hamilton - 10-22-2011, 09:15 PM
Re: Antenna choice - by gvel - 10-23-2011, 09:10 AM
Re: Antenna choice - by Tom Hamilton - 10-23-2011, 11:04 AM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3482 online users. [Complete List]
» 2 Member(s) | 3480 Guest(s)
