Batteries for the Philco 39-71!
To batterymaker, WOW. Thank you very much for reposting the pixs. I believe it is styrofoam and a plastic/phenol sheet on to it? What did you use for sockets and how were they attached to plastic/phenol? Did you manufacture those battery boxes and if so how the heck did you get them so great looking? PL
Batteries for the Philco 39-71! - by batterymaker - 06-24-2006, 12:49 PM
[No subject] - by Ron Ramirez - 09-19-2006, 09:07 AM
[No subject] - by batterymaker - 09-22-2006, 08:09 AM
[No subject] - by planigan - 09-23-2006, 08:10 PM
[No subject] - by batterymaker - 09-24-2006, 08:52 PM
[No subject] - by planigan - 09-25-2006, 12:06 PM
[No subject] - by batterymaker - 09-25-2006, 02:05 PM
[No subject] - by planigan - 09-27-2006, 10:07 AM
Philco 91 Tuning Condenser
There are currently 8675 online users. [Complete List]
» 3 Member(s) | 8672 Guest(s)
