Phuilco 41-280 / The Chassis is worse than I had expected
Only one more point of advice:
Be sure to indicate just how you want it "restored" when communicating with a tech. Do you want it repaired and cleaned up or do you want it to look period correct - only period parts and re-stuffed caps. There will be a difference in cost.
Re: Phuilco 41-280 / The Chassis is worse than I had expecte - by Phlogiston - 10-22-2011, 07:37 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
