...After condenser bank replacement in Philco 20
My TRF buzzed horribly, until I added line filter caps. Here's a good read:
<!-- m --><a class="postlink" href="http://www.justradios.com/safetytips.html">http://www.justradios.com/safetytips.html</a><!-- m -->
If you don't have a "safety" cap handy, use whatever you have of correct value and at least rated a 630V. If this solves your problem, order some safety caps and change out the temps.
-Greg
Re: ...After condenser bank replacement in Philco 20 - by gvel - 11-25-2011, 04:44 PM
91H Code 126 Restore
There are currently 5607 online users. [Complete List]
» 1 Member(s) | 5606 Guest(s)
