With time constraints, a 6SJ7 replaces a 36
It was a charred arcing path from the plate connection to ground; most likely it started with a liquid of some sort getting on the socket. Normally this is only found in audio output and rectifier stages but it's not confined to those.
Pete AI2V
Re: With time constraints, a 6SJ7 replaces a 36 - by AI2V - 10-26-2011, 09:25 AM
91H Code 126 Restore
Philco 70 antenna lead
