Philco Model 38-2XX need some dimensions please
Icon_thumbdown JROZ I hope u take the advise form all the collectors out there and don't do the unthinkable. There are repro consoles out there maybe u will find one on craigs list or ebay.
Re: Philco Model 38-2XX need some dimensions please - by Oldradiosman - 10-26-2011, 12:56 PM
There are currently 8761 online users. [Complete List]
» 3 Member(s) | 8758 Guest(s)
