Need help identifying old Philco mahogany cabinet.
The actual model number will either be on a blue and white paper tag, glued to the inside of the cabinet and visible, or it may be black ink-stamped on the rear of the chassis with also a Code number possibly.
Pictures will help us help you.
Chuck
Need help identifying old Philco mahogany cabinet. - by Michael k - 10-28-2011, 08:25 PM
Re: Need help identifying old Philco mahogany cabinet. - by Chuck Schwark - 10-29-2011, 10:24 AM
Canadian GE Model 41
Umm....you do not clean potentiometers with contact cleaner. Unless cleaning the carbon layer of the base is the goal. Y...morzh — 05:52 PM
I got the tube tested and it was TU. I have installed a replacement tube. During this last effort I discovered part of...Mtmattking — 04:01 PM
Restoring Philco 96
I opened up and lubed the volume pot. It is suposed to be 500K (no one expects it to be that), and it is about 1.5M. T...morzh — 03:34 PM
Compatible crts
The 5JP1 sounds like either like a military tube, or one built for some piece of older industrial equipment.Arran — 02:59 PM
Thank you morzh. I will try that today.R3Sons — 02:06 PM
A man who repairs tube radios is capable of many things. Capable of anything :lol: Beware.morzh — 01:40 PM
Philco 91 Tuning Condenser
Yes, in those it is. In 20/90 it is a metal spring that holds the rotor in the cradles of the outer walls.morzh — 01:39 PM
There are currently 1678 online users. [Complete List]
» 3 Member(s) | 1675 Guest(s)
