replacing rubber insulators,Philco 16x
Phlogiston Wrote:A 100W or larger "gun". Sometime I have to use and my iron, both, to get nice flow.
Thanks for the info.
Don't know where I can get one of those?
murf
replacing rubber insulators,Philco 16x - by murf - 10-29-2011, 10:08 AM
Re: replacing rubber insulators,Philco 16x - by murf - 10-29-2011, 12:40 PM
91H Code 126 Restore
Philco 70 antenna lead
There are currently 3450 online users. [Complete List]
» 2 Member(s) | 3448 Guest(s)
