37-116 2 different grill cloths?
Working on a 37-116 and I noticed that it had a different pattern of cloth behind the small cutouts. The cloth all looks old and I'm wondering if this is an old repair or was it made this way?
Note from site admin: Sorry, but the photo which was attached to this post is no longer available.
John
Las Vegas, NV USA
37-116 2 different grill cloths? - by LASJayhawk - 10-29-2011, 08:56 PM
Re: 37-116 2 different grill cloths? - by Arran - 11-01-2011, 08:00 PM
