replacing rubber insulators,Philco 16x
Texasrocker Wrote:Hi Murf, what kind of heavy duty soldering irons are avail on Amazon? Pls post link here if possible. Are they the 150 watter big irons?
Thats great you found em online!! Thanks, ol Tex.
The one I bought is just a cheap one.
Did not look for anything bigger than a 100 watt.
Just bought it for very limited use.
murf
replacing rubber insulators,Philco 16x - by murf - 10-29-2011, 10:08 AM
Re: replacing rubber insulators,Philco 16x - by murf - 10-29-2011, 09:53 PM
The speaker table error?
Philco 70 antenna lead
