37-116 2 different grill cloths?
It's an old repair, because neither pattern is correct.
It should have the 1935-37 "V" pattern cloth in all three openings:
[Image: http://i326.photobucket.com/albums/k420/..._cloth.jpg]
Of course, now that this pattern is no longer being reproduced, unless/until someone else begins to reproduce the cloth again, we have to make do as best we can, just like we did before reproduction grille cloth became available.
37-116 2 different grill cloths? - by LASJayhawk - 10-29-2011, 08:56 PM
Re: 37-116 2 different grill cloths? - by Ron Ramirez - 10-30-2011, 08:15 AM
Re: 37-116 2 different grill cloths? - by Arran - 11-01-2011, 08:00 PM
There are currently 6981 online users. [Complete List]
» 1 Member(s) | 6980 Guest(s)
