resistor wattage
Hi Guy,s
Replacing some resistors on my RCA model 816k radio and have a question about a resistor shown on the schematics.
Its labeled c30 on the schematics.
It is specified as a 320 ohm carbon type resistor,but I am not able to read what the wattage is on my parts list.
Any body know if this one is a 1/4 watt or a 1/2 watt resistor?
THanks,
murf
resistor wattage - by murf - 12-16-2011, 08:14 AM
Re: resistor wattage - by Carl Travis - 12-16-2011, 11:40 AM
Re: resistor wattage - by murf - 12-16-2011, 01:57 PM
There are currently 8916 online users. [Complete List]
» 3 Member(s) | 8913 Guest(s)
