Truetone D2210
Texasrocker Wrote:I certainly agree about epay Jayce. I just mentioned the restored Truetone D-723 that is listed so you can see a nice example of one, and with the colorful dial lit up in the photos. The price went higher than I would have paid for it also, especially without the correct knobs.
Congrats on getting your Stromberg Carlson home after your long trip. Bet it will be a great sounding set after restoration! Icon_thumbup
I still thabk you all around. I got a look at one of the Truetones and they are very nice indeed. The Stromberg shows the promise to be a good performer and a bit of a thumper once I get the bugs out of it. My friend already did a good bit of work to this set already including creating a new speaker surround for it since the leather was shot.
Truetone D2210 - by Jayce - 10-14-2011, 07:34 PM
Re: Truetone D2210 - by TA Forbes - 10-14-2011, 10:36 PM
Re: Truetone D2210 - by Jayce - 10-14-2011, 10:47 PM
Re: Truetone D2210 - by Texasrocker - 10-15-2011, 08:51 PM
Re: Truetone D2210 - by Jayce - 10-15-2011, 10:43 PM
Re: Truetone D2210 - by exray - 10-16-2011, 05:36 AM
Re: Truetone D2210 - by Arran - 10-16-2011, 11:38 PM
Re: Truetone D2210 - by Texasrocker - 10-16-2011, 11:47 PM
Re: Truetone D2210 - by Texasrocker - 10-17-2011, 12:03 AM
Re: Truetone D2210 - by TA Forbes - 10-17-2011, 08:44 AM
Re: Truetone D2210 - by Jayce - 10-17-2011, 02:09 PM
Re: Truetone D2210 - by TA Forbes - 10-17-2011, 11:38 PM
Re: Truetone D2210 - by Jayce - 10-18-2011, 11:59 AM
Re: Truetone D2210 - by Texasrocker - 10-29-2011, 08:16 PM
Re: Truetone D2210 - by Jayce - 10-29-2011, 11:14 PM
Re: Truetone D2210 - by Texasrocker - 10-30-2011, 03:39 PM
Re: Truetone D2210 - by Jayce - 10-30-2011, 05:24 PM
Re: Truetone D2210 - by philconerd - 11-30-2011, 10:20 PM
Philco 91 Tuning Condenser
There are currently 10162 online users. [Complete List]
» 2 Member(s) | 10160 Guest(s)
