118H, Original Wood Color/Finish-Updated with Photo
Ron,
Great site and appreciate all you do! If I can find the original source of the other 118H photo I added I will contact them for permission. Best I can remember it was some radios at an auction someone was looking at to buy.
Arran,
I am learning a bunch about cabinets, I see the added dark toning around the tuning knob.
Mike
Cossor 3468
GE 417A
Philco 118H
Radiola 17/100
Scott 800B6
Silvertone 6130
Stromberg 535M
Truetone D1952
There are currently 10933 online users. [Complete List]
» 3 Member(s) | 10930 Guest(s)
