Philco 60 Alive Again!
#33
As an update, I've removed the tuning condenser from the set. Now all of the non-moving stator plates are isolated from the frame. The wire that goes from the rear most connection of the condenser, to pin 5 of the 6A7 reads 45K Ohms.
-Brett
Philco 60 Alive Again! - by Caperodder - 12-02-2011, 04:04 PM
Re: Philco 60 Alive Again! - by Chicago Jimmy - 12-02-2011, 06:21 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-02-2011, 07:14 PM
Re: Philco 60 Alive Again! - by Phlogiston - 12-02-2011, 07:56 PM
Re: Philco 60 Alive Again! - by Ron Ramirez - 12-02-2011, 08:40 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-02-2011, 09:30 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-02-2011, 09:58 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 09:04 AM
Re: Philco 60 Alive Again! - by gvel - 12-03-2011, 09:09 AM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 09:50 AM
Re: Philco 60 Alive Again! - by 7estatdef - 12-03-2011, 05:19 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 06:05 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 06:45 PM
Re: Philco 60 Alive Again! - by Ron Ramirez - 12-03-2011, 07:27 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 07:34 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 10:06 AM
Re: Philco 60 Alive Again! - by Caperodder - 12-04-2011, 11:06 AM
Re: Philco 60 Alive Again! - by morzh - 12-04-2011, 12:46 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-04-2011, 01:16 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 03:05 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-04-2011, 06:37 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 07:04 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 11:49 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 11:20 AM
Re: Philco 60 Alive Again! - by 7estatdef - 12-05-2011, 12:11 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 03:46 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-05-2011, 04:12 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 05:53 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-05-2011, 06:25 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 07:20 PM
Re: Philco 60 Still dead - by 7estatdef - 12-05-2011, 10:09 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 11:01 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 11:19 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-07-2011, 09:18 AM
91H Code 126 Restore
There are currently 5585 online users. [Complete List]
» 1 Member(s) | 5584 Guest(s)
