Hello all...
I've passed up several sets this model, simply because I like Philcos that are bigger, and that are the fine performers that they're noted for. There are others of us who can appreciate a less expensive radio like the model 610, or whatever.
But, if you wanted to play your modern storage device through something, why did it have to be a set that had been intact?
I like to play records from my collection on vintage phono combination radios, or the newer discs on my fisher 800B and E-V Patricians, when I want to go big, (and nobody else to overtax their ears).
I've had several people show me a "masterpiece" like yours. My usual comment is: Aaaargh!
Hello all... - by H_Roark - 11-30-2011, 07:54 PM
Re: Hello all... - by Ron Ramirez - 11-30-2011, 08:55 PM
Re: Hello all... - by Arran - 11-30-2011, 11:43 PM
Re: Hello all... - by TA Forbes - 12-01-2011, 12:29 AM
Re: Hello all... - by H_Roark - 12-01-2011, 08:46 AM
Re: Hello all... - by Doug Houston - 12-06-2011, 01:28 AM
Philco 91 Tuning Condenser
There are currently 5810 online users. [Complete List]
» 3 Member(s) | 5807 Guest(s)
