Presenting the Stromberg-Carlson 12A!
Nice looking set! Too bad it's not a superhet. It's a trf with avc,a lot like a Philco 95. Even has a S meter. Took a look at the diagram doesn't look like it's much fun to work on.
Presenting the Stromberg-Carlson 12A! - by Jayce - 10-31-2011, 07:38 PM
Re: Presenting the Stromberg-Carlson 12A! - by 7estatdef - 10-31-2011, 09:37 PM
Philco 91 Tuning Condenser
There are currently 8155 online users. [Complete List]
» 3 Member(s) | 8152 Guest(s)
