Philco 60 Alive Again!
What i do is scrape off the open winding with my fingernail. Use a heat gun clean up the area. Solder on the wire at the bottom of the winding Starting from the bottom wind the new turns in a cw direction. Solder on the top of the winding. Wire gauge is not very critical. RS probably has something that is close like 34 or 36g.
Philco 60 Alive Again! - by Caperodder - 12-02-2011, 04:04 PM
Re: Philco 60 Alive Again! - by Chicago Jimmy - 12-02-2011, 06:21 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-02-2011, 07:14 PM
Re: Philco 60 Alive Again! - by Phlogiston - 12-02-2011, 07:56 PM
Re: Philco 60 Alive Again! - by Ron Ramirez - 12-02-2011, 08:40 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-02-2011, 09:30 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-02-2011, 09:58 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 09:04 AM
Re: Philco 60 Alive Again! - by gvel - 12-03-2011, 09:09 AM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 09:50 AM
Re: Philco 60 Alive Again! - by 7estatdef - 12-03-2011, 05:19 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 06:05 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 06:45 PM
Re: Philco 60 Alive Again! - by Ron Ramirez - 12-03-2011, 07:27 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-03-2011, 07:34 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 10:06 AM
Re: Philco 60 Alive Again! - by Caperodder - 12-04-2011, 11:06 AM
Re: Philco 60 Alive Again! - by morzh - 12-04-2011, 12:46 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-04-2011, 01:16 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 03:05 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-04-2011, 06:37 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 07:04 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-04-2011, 11:49 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 11:20 AM
Re: Philco 60 Alive Again! - by 7estatdef - 12-05-2011, 12:11 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 03:46 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-05-2011, 04:12 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 05:53 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-05-2011, 06:25 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 07:20 PM
Re: Philco 60 Still dead - by 7estatdef - 12-05-2011, 10:09 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 11:01 PM
Re: Philco 60 Alive Again! - by Caperodder - 12-05-2011, 11:19 PM
Re: Philco 60 Alive Again! - by 7estatdef - 12-07-2011, 09:18 AM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
