Two More Questions on Philco bakelite caps and values
As usual, thanks for the response Terry. Shall go with the .1 and 200 ohm.
Jerry
Re: Two More Questions on Philco bakelite caps and values - by jerryhawthorne - 11-02-2011, 02:07 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6050 online users. [Complete List]
» 1 Member(s) | 6049 Guest(s)
