Grandpa's radio
It's a good thing that the dial bezel is in good condition because there are no reproduction ten pushbutton escutcheons available at this time. If it was really bad the only way that I can think of to replace it would be to take two of the reproduction nine pushbutton bezels, cut them, and then to graft them together with the appropriate glue. I don't know what sort of plastic these reproduction bezels are made out of but I'm guessing it's polystyrene, if it is then it is possible to cut two apart to make a ten pushbutton escutcheon, if everything measures out. If the dial of these 42-395 sets is the same width as a 42-380 then it may not work.
One shortcoming that all American Philcos made between 1939 and 42 have is rubber covered wiring where the insulation tends to harden and disintegrate. It isn't too difficult to replace of sleeve this wiring is you are slow and meticulous, but I wouldn't try rewiring a nine tube set as your first restoration project. I would pick up a five tube AC transformer set to practice on as it is closer to your grandfather's radio in design and there is less of a shock hazzard. Some would suggest an AA5 but the power supply works differently then an AC set and U.S AA5s often have a hot chassis where the steel of the chassis is connected directly to one side of the power line, Philco AA5s do not but the chassis are often overcrowded things to work on and frustrating for a beginner.
P.S I just looked at the 42-395 and the 42-380 in the gallery again, I think that the knob spacing is different so the cut and graft idea may not work.
Grandpa's radio - by emmpro - 11-02-2011, 02:56 PM
Re: Grandpa's radio - by 7estatdef - 11-02-2011, 05:16 PM
Re: Grandpa's radio - by codefox1 - 11-02-2011, 06:40 PM
Re: Grandpa's radio - by Arran - 11-02-2011, 11:20 PM
Re: Grandpa's radio - by exray - 11-03-2011, 06:50 AM
Re: Grandpa's radio - by emmpro - 11-03-2011, 01:33 PM
Sorry, point 19 was 10vR3Sons — 09:11 PM
Thank you morzh. I sincerely appreciate the advice. That's why I'm here. I am ready and eager to learn. I have a lot...R3Sons — 09:10 PM
R3, Let me ask you this: how much, if any, experience do you have in radio repair? If you don't have much, I suggest th...morzh — 08:42 PM
Well.... Test point 12 is confusing. The capacitor shown is not there. Apparently it was optional. One radio is pull...R3Sons — 08:25 PM
1950 Emerson TV resurrection attempt
I know from experience: there's nothing like the feeling of having just fixed the problem thatyou yourself created. :lol...morzh — 08:15 PM
Restoring Philco 96
Spraying Deoxit inside did the job; today it was dry and still showing 0.25 Ohm when the switch is made. So, I put it...morzh — 07:49 PM
Thanks Rich! This is kinda typical in TV work and is one reason I don't shotgun things. If something like this goes wron...TV MAN — 05:17 PM
Hello Tim, Yes, don't you hate when things go like that and go snap ? Anyway lots of progress on your tv . Sincerel...radiorich — 03:32 AM
I needed to loosen the HV tube socket, so that meant removing the 1B3. The getter looked ok, so I'll reuse the tube. I c...TV MAN — 01:40 AM
Today I got some final (I hope) work done. I know there are some that absolutley blast me because ... "WHY don't yo...TV MAN — 01:11 AM
There are currently 2560 online users. [Complete List]
» 2 Member(s) | 2558 Guest(s)
